KCS MQTT ANALOG
Hi, I am trying KCS.
It sends Mqtt frames with all data (Input+relay+analog+DAC).
Only inputs and outputs changes are updated by a mqtt frame.
When analog and DAC changes, there is no mqtt updates.
I tried to parameterize the threshold, but no way
Quite important to get them updated without any changes in input and output.
Thanks
can you take some photo of your problem, about your setting and which board you are using? if you can take a video is better.
My video do not upload (80Mo). I am sending two pictures. Thanks
video file can upload to google driver, then give us download URL.
https://drive.google.com/file/d/1OJRZrtf...sp=sharing
ok, we will feedback to our software engineer. please list MQTT topic you are using.
Is this what you need?
(06-15-2023, 10:35 PM)philippe Wrote: Hi, I am trying KCS.
Thanks
About KC868-A4 firmware  Input and output and analog and DAC all MQTT send is OK
Picture 01
Picture 02
Picture 03
Picture 04
Thanks
Let me rephrase my problem. Yes in one Mqtt frame , I get everything updated ( relay,input,analogic...). The problem is that this frame is only sent when a relay or digital input changes.
If only an analogic input changes, there is no mqtt frame being sent. This is what one of my pictures shows.
Reply:
I Was test the problem,KC868-A4 power on and do nothing,just set the value of Analog4 when the value up to 2000,it will send mqtt command,no relay control no input trigger,when analog 4 is connect to 3V,it will send the value about 2596 .See the picture below.
Sorry, there is no mqtt update on my side. See my video.I increase the sensor temperature. KCS reflects this increase, bt there is no mqtt frame being sent to mqtt explorer.
https://drive.google.com/file/d/1wZtfjjR...sp=sharing
