KC868-1U-ha-config.txt (Size: 5.76 KB / Downloads: 611)
platform: ESP32
remote_receiver:
pin: 13
dump:
- rc_switch
tolerance: 50%
filter: 250us
idle: 2ms
buffer_size: 2kb
sda: 4
scl: 16
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
# Optional manual IP
# manual_ip:
# static_ip: 192.168.1.199
# gateway: 192.168.1.1
# subnet: 255.255.255.0
address: 0x24
address: 0x22
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
on_press:
then:
- switch.toggle: light1
pcf8574: pcf8574_hub_in_1
on_press:
then:
- switch.toggle: light2
on_press:
then:
- switch.toggle: light3
on_press:
then:
- switch.toggle: light4
on_press:
then:
- switch.toggle: light5
number: 4
on_press:
then:
- switch.toggle: light6
number: 5
on_press:
then:
- switch.toggle: light7
number: 6
on_press:
then:
- switch.toggle: light8
number: 7
- platform: remote_receiver
rc_switch_raw:
code: '001111010111001010111000'
protocol: 1
on_press:
then:
filters:
- delayed_off: 200ms
rc_switch_raw:
code: '001111010111001010111100'
protocol: 1
on_press:
then:
filters:
rc_switch_raw:
code: '001111010111001010110100'
protocol: 1
on_press:
then:
filters:
rc_switch_raw:
code: '001111010111001010111001'
protocol: 1
on_press:
then:
filters:
rc_switch_raw:
code: '001111010111001010110010'
protocol: 1
on_press:
then:
filters:
rc_switch_raw:
code: '001111010111001010110101'
protocol: 1
on_press:
then:
filters:
rc_switch_raw:
code: '001111010111001010110001'
protocol: 1
on_press:
then:
filters:
rc_switch_raw:
code: '001111010111001010110011'
protocol: 1
on_press:
then:
filters:
dallas:
- pin: 14
update_interval: 5s
- platform: dallas
address: 0xa538cee908646128
name: "1U Temperature"
