how to add multiple controllers to home assistant? by MQTT
How to describe configuration.yaml
I have two controllers KC868H32B version 4.20
mqtt:
  broker: 192.168.0.10    #home assistant IP
  port: 1883                   #Port
  username: abc # first controller
  password: 123
                        # how to add second or the third controller?
And how to add severals controllers to Mosquitto broker configuration?
Mosquitto broker configuration is same, not need to changed.
just in configuration.yaml add multi controller with different UID in topic.
(04-27-2021, 06:04 AM)admin Wrote: Mosquitto broker configuration is same, not need to changed.
In all controllers use the same user name and password?
mqtt user name and password is same, because your home assistant have use only 1 Mosquitto broker.
(04-27-2021, 06:04 AM)admin Wrote: ... just in configuration.yaml add multi controller with different UID in topic.
Please write an example of such an entry in configuratin.yaml for 2 controllers.
after we finished holidays, we will have a test.
firmware updated, fixed problem: https://www.kincony.com/forum/showthread.php?tid=268
