how to add Raspberry Pi GPIO integration to home assistant for SERVER-MINI
1. make home assistant SD card for KinCony Server-16.
download  https://www.raspberrypi.com/software/
2. install HACS addon (use by SSH)
https://hacs.xyz/docs/setup/download/
3. install "rpi_gpio" through HACS.
https://github.com/thecode/ha-rpi_gpio
4. config ymal for CM4 GPIOs.
install file edit add-on for HA , then config yaml
  - platform: rpi_gpio
    switches:
      - port: 5
      - port: 22
      - port: 17
      - port: 4
      - port: 6
      - port: 13
      - port: 19
      - port: 26
    sensors:
      - port: 18
        invert_logic: true
      - port: 23
        invert_logic: true
      - port: 24
        invert_logic: true
      - port: 25
        invert_logic: true
      - port: 12
        invert_logic: true
      - port: 16
        invert_logic: true
      - port: 20
        invert_logic: true
      - port: 21
        invert_logic: true
How to synchronize a physical button with a KinCony Server-Mini Raspberry Pi4 relay module?
Please give examble code!
When a physical button or switch is connected as a binary input,
For example, in the code you provided, port 18 is configured as a binary input (CM4 IN1). When this input is low, the Raspberry Pi will enable port5 CM4 relay1,
When the input is high, the Raspberry Pi will disable CM4 relay1.
if you are using home assistant, just create "AUTOMATION" in home assistant, when INPUT trigger OUTPUT "TOGGLE" is ok.
(08-29-2023, 10:04 PM)admin Wrote: if you are using home assistant, just create "AUTOMATION" in home assistant, when INPUT trigger OUTPUT "TOGGLE" is ok.
How it work offline or when network fail, is it work?
it can work without network.
I'm sorry to resume this topic, but if I don't want to use AUTOMATION from HA, what would be the code to turn on relay 1 with input 1 ??... for example.... Regards
another way, you can install Node-Red software, link the INPUT with OUTPUT. at firstly you need install one software for CM4.
