Hello, i have a KC868-A8 Board connected with ethernet cable but the port suddenly stopped working. The port indicators are both flashing and the board keeps restating every 15min because it searches for a ethernet connection. I use it with ESPhome and home assistant. If i re-flash the esp32 with a WIFI configuration everything works but when i try to use the Ethernet port i get an error and it goes offline in esphome. (Component ethernet was marked as failed.)
Here is my code -
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
manual_ip:
static_ip: 192.168.1.154
gateway: 192.168.1.1
subnet: 255.255.255.0
Any ideas on how to fix this ?
Here is my code -
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
phy_addr: 0
manual_ip:
