Wifi controller devices inside metal enclouser
Is the Wifi signal can reach the wireless controllers in closed metal enclousers as your video.
Or we need PVC enclosure with transparent door for get good signal if no availability to ether
net cables?
not install relay controller in a closed metal box, if you want to use wifi.
if you really want to install inside, please connect with a extend wifi antena outside box.
Send the link please for this product and do i need it for each controller inside the box and what about the pvc / plastic box and possible transparent door?
such as this extend wifi antena, use SMA connect to KinCony's controller.
