  • 1 Vote(s) - 5 Average
[Arduino IDE demo source code for KC868-A8]--#05-LAN8720-UDP
Star
Code 4: //The demo code is LAN8720-UDP    You can copy the code to your Arduino IDE
#include <ETH.h>
#include <WiFiUdp.h>
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN   18
#define ETH_TYPE       ETH_PHY_LAN8720
#define ETH_CLK_MODE   ETH_CLOCK_GPIO17_OUT
IPAddress local_ip(192, 168, 2, 200);
IPAddress gateway(192, 168, 2, 1);
IPAddress dns(192, 168, 2, 1);
void setup()
  Serial.println();
  Serial.println("Connected");
  Serial.print("IP Address:");
void loop()
  if (packetSize)                     //if have received data
    char buf[packetSize];
    Serial.println();
    Serial.print("Received: ");
    Serial.println(buf);
    Serial.print("From IP: ");
    Serial.print("From Port: ");
    Udp.print("Received: ");
