12-30-2020, 03:07 PM
Dear Admin
i need help on the KC868-COLW logical controller. in my house i was using IP 192.168.1.xxx. When i purchase the KC868-COLW logical controller i did the setup. It has been some time since i set it up. I now need to do a reset as the KC868-COLW logical controller as it is now in a new location and the router is now using IP 192.168.8.xxx.
If i reset the KC868-COLW logical controller, how do i get access to the KC868-COLW logical controller to configure the WiFi to access this new SSID and IP? Do i need to connect to the KC868-COLW logical controller using a LAN Cable or i can use the built in WiFI. When i reset the KC868-COLW logical controller, what is the default SSID for me to access the configuration?
i know i have to use the Application VirCom but what IP should i use and port number? i was looking for the "How to setup KC868-COLW logical controller" on your website and i am not able to find it. Please help!
Thank You
Regards
Subas
Regards
Subas
