  • 1 Vote(s) - 5 Average
KC868-E16S ESP32 I/O pin define
ANALOG_A1  GPIO36
ANALOG_A2  GPIO35
ANALOG_A3  GPIO34
ANALOG_A4  GPIO39
IIC SDA:GPIO16
IIC SCL:GPIO15
PCF8574:U27 (relay1-8): 100 001 = 0x21
PCF8574:U28 (relay9-16): 100 101 = 0x25
PCF8574:U23 (DI1-8): 100 010 = 0x22
PCF8574:U24 (DI9-16): 100 100 = 0x24
RF433MHz wireless receiver: GPIO4
BEEP:GPIO2
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN  18
RS485:
RXD:GPIO13
TXD:GPIO32
Extend serial port (3.3v TTL level):
RXD:GPIO14
TXD:GPIO33
Hi do you have upgraded wiring diagram and I/O pin define for vestion1.4?
not changed pin define.
What about wiring diagram, I can see some difference eg. NTC TErmistor and Temp and hum. sensor on board?
To witch i2c bus I can use to read this sensos?
https://www.kincony.com/download/KC868-E...ematic.pdf
