  • 1 Vote(s) - 5 Average
KC868-A4 esphome yaml config for home assistant
  platform: ESP32
  board: esp32dev
ota:
  password: "4d5a388de4f759bf88e71cde7a31af6f"
wifi:
  ssid: "KinCony"
  password: "a12345678"
  ap:
    ssid: "Kc868-A4 Fallback Hotspot"
    password: "QOU4hbAjJ5Wb"
captive_portal:
    pin: 2
    inverted: false
    pin: 15
    inverted: false
    pin: 5
    inverted: false
    pin: 4
    inverted: false
      number: 36
      number: 39
      number: 27
      number: 14
.txt   Made_for_ESPHome_KC868-A4.txt (Size: 1.1 KB / Downloads: 1,277)
Hi, i got my A4. Question is: Is it possible to connect A4 to home assistant using KCS firmware?
sure, you can add A4 to home assistant by MQTT, just enable MQTT protocol in KCS webpage.
So your devices doesint have direct communication with home assistant? Sad
if you want device directly communication with home assistant, you can download firmware by ESPHome, not need to use KCS firmware. we suggest use this, now just your question is how to use KCS firmware for home assistant.
Ok, thank you, finnaly added A4 to home assistant Smile
ok, good.
