how to move CM4 eMMC home assistant data to USB driver
if you are using CM4 8G eMMC version, installed home assistant and add-on. when you have not enough space of eMMC, you can use "movedata disk" function, that can move your data to USB disk, save your eMMC space. it's easy.
[Image: attachment.php?aid=1181]
Good morning,
I have low disk space, how to do? I can't find the commands.
Also because, as in another question, the USB ports are not working.
Thank you
have replied you this quesiton how to enable USB port in CM4 at another topic.
