PC software update V1.0.407.0220 for KC868-COL and KC868-COLB logical controller.
user not need update firmware, only replace with new PC software package is ok.
download link: https://www.kincony.com/download/Kincony...7.0220.zip
V1.0.407.0220 improvement:
1. remember C/F temperature setting, re open the software will remember use C or F unit last time setting.
2. fixed IF condition temperature value can't input decimal number.
3. IFTTT debug information replace some character with < >, channel number ... etc
4. add remarks function for every IFTTT command, so that user can easy to understand every IFTTT command means
5. support use analog temperature sensor for AI port that range can use by "-" Negative temperature. Such as analog temperature rage from -20℃----+80℃
