KC868-H32B relay controller will support http webpage control soon
Wink
KC868-H32B relay controller will support http get command for software developer. This is a new way for integration to third software platform.
example for turn ON/OFF relay 1 command:
http://192.168.1.10/sw_ctl.cgi?Relay01=O...d=admin123    // relay1 ON
http://192.168.1.10/sw_ctl.cgi?Relay01=O...d=admin123  // relay1 OFF
http://192.168.1.10/sw_ctl.cgi?Relay02=O...d=admin123    // relay2 ON
http://192.168.1.10/sw_ctl.cgi?Relay02=O...d=admin123  // relay2 OFF
every board will have password inside.
Nice feature. What is a command for all off? I don't see feedback in receive buffer in Node-RED when uses any link command
I have a Kincony KC868-H32 although I'm not sure if I now have the KC868-H32B or KC868-H32L model.
Is there a way to verify this?
On the metal cover the model number starts with H32B2007XXXXX and when using the VirCom software I can see Firmware version is V1.598.
Is it possible to use this HTTP feature with my device then?
Thank you for your help!
it's H32L, H32B have orange color teminal.
And is there a way to switch the relays through HTTP commands on the H32L?
If so which firmware version would be needed?
Thx!
sorry, only KC868-H32B support http command. no firmware for H32L
Too bad, is the following that would work on the H32L or is this H32 article/video about yet another version of the controller?
https://www.kincony.com/kc868-h32-relays...owser.html
this is control by cloud server using http command. not send http command to controller directly. because H32L CPU memory is small, no space for update.
