[Arduino source code for KC868-A4]-17 homekit work with 4 relay and 4 switch buttons
Big Grin
this arduino source code for KC868-A4 work with 4 relay and 4 momentary switch buttons via Apple homekit app. you can download the BIN firmware directly without chanage any code. Or you can open arduino source code project to compile.
here are KC868-A4 board with 6 gang switch panel (actually I have used 4 buttons) and iPhoneXR.
this is demo video:
here is source code:
.zip   RealPushButtons-4DO-4DI.zip (Size: 624.09 KB / Downloads: 1,224)
this is firmware and source code, BIN file included.
if you want to use source code, you should do:
1. install ESP32 V2 board in arduino IDE.
2. install "homespan" library for arduino.
after you downloaded firmware, first time to use, need type "W" in serial monitor, chose number of wifi SSID, input password.
then use your iPhone or iPad to pair KC868-A4.
Good morning, I had sent a request for help from youtube; I installed version 2.09 esp32 x HomeSpan, now the program works
I don't have an Apple iphone.
I'm sorry, I'm a beginner and I'm learning to use your wonderful products.
Good day.
what need help now?
for now no help. It was just to inform you, on you tube she had told me to write on the forum; I am now following his other lessons on the use of the KC868-A4.
Thank you
ok
(09-13-2022, 02:51 AM)admin Wrote: this arduino source code for KC868-A4 work with 4 relay and 4 momentary switch buttons via Apple homekit app. you can download the BIN firmware directly without chanage any code. Or you can open arduino source code project to compile.
this is demo video:
HI ,
does realys in kc868 A4 board can control Air Conditioner?
not suitable, do you want to control Air Conditioner's power line? for AC220v ON/OFF? if yes, it's not safety, A4's relay is max 10A for load. Air Conditioner suggest use 25A contactor is safety.
(09-25-2023, 10:26 PM)admin Wrote: not suitable, do you want to control Air Conditioner's power line? for AC220v ON/OFF? if yes, it's not safety, A4's relay is max 10A for load. Air Conditioner suggest use 25A contactor is safety.
Can you send me A4 board circuit diagram?
download from here: https://www.kincony.com/document
