help me choose the components of a smart system for 3 floors building
I hope to help me choose the components of a smart system for 3 floors building, including controllers, circuit breakers, contactors, and ssr ......
[b]Ground floor:[/b]
20 lighting circuits on / off
9 dimmer lighting circuits
2 heater circuits with control switches
4 air conditioner circuits with control keys
1 garage control circuit
_________________________________________
 First floor
14 lighting circuits on / off
10 dimmer lighting circuit
3 heater circuit with control switches
Second floor
11 lighting circuits on / off
7 dimmer lighting circuit
5 air conditioner circuit with control switches
No 26 dimmer switch
No 22 switch for aircondition and weter heater
No 4 switch 1 gang
No 16 switch 2 gang
No 6 switch 3 gang
No 5 switch 4 gang
No 2 switch 5 gang
No 2 switch 6 gang
do you will use home assistant software?
Yes i will use home assistant and tyua software
you can use KC868-Server for install home assistant.
KC868-D16 dimmer controller.
about relay controller we will release soon that support home assistant and Tuya, suggest wait for a moment.
so that all system can work with home assistant locally and tuya control device by internet.
Share please later your pics here. I would additionally add a control button to your list
KC868-Server: https://www.kincony.com/home-automation-...erver.html
KC868-D16: https://www.kincony.com/16-channel-tuya-...odule.html
switch button: https://www.kincony.com/product/switch-button
relay controller later i will update to you when have new webpage link.
Ok
But what are control of AC?
KC868-AG work for home assistant via IR to control your air conditioner.
if want use IR by tuya, you can chose any tuya IR device (actually KinCony will release it soon)
Thanks
you are welcome.
