Kincony a-16 using esphome toggle relays at boot up time
I am using kincony a16 with 16 relay board with esphome running but at the boot time all the relays  toggle  and make the relays on and off ...is their a way to stop this in the software side..this is become a big problem for me due all the appliance connect to relays suddenly become active and then turn off at the a16 booting up....below is my config
substitutions:
  name_add_mac_suffix: false
  project:
    version: "1"
esp32:
  board: esp32dev
web_server:
  port: 80
dashboard_import:
  package_import_url: github://hzkincony/kc868-a16/kc868-a16.yaml@main
ota:
  password: "1234"
wifi:
  ssid: "router"
  password: "1234"
  use_address: 192.168.8.114
  manual_ip:
    static_ip: 192.168.8.114
    gateway: 192.168.8.1
    subnet: 255.255.255.0
  sda: 4
  scl: 5
  scan: false
# Example configuration entry
# ethernet:
#  type: LAN8720
#  mdc_pin: GPIO23
#  mdio_pin: GPIO18
#  clk_mode: GPIO17_OUT
#  phy_addr: 0
pcf8574:
  - id: "pcf8574_hub_out_1" # for output channel 1-8
    address: 0x24
  - id: "pcf8574_hub_out_2" # for output channel 9-16
    address: 0x25
  - id: "pcf8574_hub_in_1" # for input channel 1-8
    address: 0x21
  - id: "pcf8574_hub_in_2" # for input channel 9-16
    address: 0x22
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      number: 1
      mode: OUTPUT
      inverted: false
      number: 2
      mode: OUTPUT
      inverted: false
      number: 3
      mode: OUTPUT
      inverted: false
      number: 4
      mode: OUTPUT
      inverted: false
      number: 5
      mode: OUTPUT
      inverted: false
      number: 6
      mode: OUTPUT
      inverted: false
      number: 7
      mode: OUTPUT
      inverted: false
      pcf8574: pcf8574_hub_out_2
      mode: OUTPUT
      inverted: false
      number: 1
      mode: OUTPUT
      inverted: false
      number: 2
      mode: OUTPUT
      inverted: false
      number: 3
      mode: OUTPUT
      inverted: false
      number: 4
      mode: OUTPUT
      inverted: false
      number: 5
      mode: OUTPUT
      inverted: false
      number: 6
      mode: OUTPUT
      inverted: false
      number: 7
      mode: OUTPUT
      inverted: false
we will test your config code, then feedback to you.
you can try go use this config code, not your issue:
esp32:
  board: esp32dev
  framework:
    type: arduino
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.1.199
    gateway: 192.168.1.1
pcf8574:
    address: 0x24
    address: 0x25
    address: 0x21
    address: 0x22
    interlock: [a16output2]
      mode: OUTPUT
    interlock: [a16output1]
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      pcf8574: pcf8574_hub_in_1
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      pcf8574: pcf8574_hub_in_2
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
