WebUI over wifi STA mode
Hi KinCony IoT,
Is it possible to reach the WebUI over Wifi in STA mode to manage the relays?
I can reach the webUI over LAN port.
Both Ethernet and Wifi are set to TCP-Server.
I was able to configure Wifi in STA mode and connect to my Wifi router. Then I disconnect the wired LAN port, but when I try to connect to the relay over the Wifi IP it doesn't give back the Relay Web UI, but the Wifi ESP32 config UI.
I would like to use HTTP commands over Wifi. Is it possible?
do you using KC868-H32B? now config only by ethernet cable, it's the most stable. i suggest use ethernet for integration. if you must want to use wifi, you can use TCP protocol command, here is details: https://www.kincony.com/smart-controller...tocol.html
(11-07-2022, 12:16 AM)admin Wrote: do you using KC868-H32B? now config only by ethernet cable, it's the most stable. i suggest use ethernet for integration. if you must want to use wifi, you can use TCP protocol command, here is details: https://www.kincony.com/smart-controller...tocol.html
Yes it is KC868-H32B. I'll check the development protocol. Looks also sufficient.
"TCP" experience is better than "HTTP". because will auto feedback message when key is pressed.
