COLB timer and hxb
Hello , i have some questions about colb and hxb
1-How can i use pc software colb program timer, can i do it like : if saturday 12:30 turn on relat 1,6,9 for example? Or i must choose date and time and also which DI or AI to control the relays?
2- does h32b , h16b works on tuya app?
3- can i make timer on kincony smart home to if tome is 12:40 turn on relay 2 , then at 1:30 turn off relay 2?
4- i have an hmi, can i connect h32b and colb to it? Is there a way? Or i just buy an hmi with windows and download kincony smart home app on it and problem solved?
5- if i make scene mode (motor up) relay 1 on relay 2 off, (motor down) relay 1 off relay 2 on, is it dangerous on motor? Because when i tried it it seemed like there is delay and im scared that motor will broke up, is it better to do interlock system? Or by scene mode is enough?
1. sure, you can use COLB pc software to set if saturday 12:30 turn on relat 1,6,9
here is COLB pc software download link:
https://www.kincony.com/download/Kincony...10.504.zip
here is how to use it online guide:
https://www.kincony.com/how-to-use-kc868...oller.html
about the timer, see this photo, check the "week" option and set the TIME for IF command.
[Image: ifttt-if-eng.png]
2. H32B and H16B not support tuya app directly, if you add our tuya adapter will support to use tuya app. if you buy H32B Pro will support to use Tuya app directly.
3. sure, no problem, just two step.
step1- create scene mode on "kincony smart home" app for turn ON relay2.
video tour: https://youtu.be/XzfLEUbYxI0
step2- set a TIMER work with "scene" mode you have created in step-1
video tour: https://youtu.be/yo2V5dTE43A
4. two way:
    a. connect H32B by RS232 or network to your HMI device, you need to program code on your HMI device. you need to see HMI device user manual.
    b. just buy a windows OS pad, install our pad software to use H32B and COLB. here is software download link for 10 inch windows Pad:
https://www.kincony.com/download/MulitiB...3.0324.zip
5. not not need to create scene mode for relay1 on, relay2 off. you can update your H32B firmware to the newest version, will support "interlock" function, so that can make sure two relay will never turn ON at the same time by hardware.
here is the newest firmware of H32B:
https://www.kincony.com/forum/showthread.php?tid=2343
1- about “week” option where is it exactly? Or i just click tick on which day i want? As i said i tried to tick on saturday and time xx:xx added if then turn on relay 1 but didnt work are you sure its done like that?
4- on this pad i can download also kincony smart home app? Kbox? And pc software colb? Yes?
Here is a video on how i did it, did i do something wrong that it didnt work?
https://files.fm/u/bcs5cjtru
1. do you see my photo on right window? you can post your setting screen photo, i want to see how you setting. Do you have set the COLB board's system time fistly?
2. on Pad only install by these two software:
https://www.kincony.com/download/KBOX-Pad.zip
1- what is that exactly how to set the colb system time? As shown in the video the time on the software is the same as i set timed
[Image: hardware-setting-eng.png]
just set the time for board, click "Set RTC"
