KC868-A2 ESP32 I/O pin define
Relay1:15
Relay2:2
DS18B20/DHT11/DHT21/LED strip -1: 33
DS18B20/DHT11/DHT21/LED strip -2: 14
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN  18
RS485:
RXD:35
TXD:32
GSM:
RXD:34
TXD:13
DI1:36
DI2:39
IIC BUS:
SDA:4
SCL:16
Can u show every pın number ın thıs pıcture.Green termınal,black termınal etc.I'm newbıe sorry Sad
pin define: https://www.kincony.com/forum/showthread.php?tid=2691
[Image: KC868-A2-1_05.jpg]
in photo GPIO-1 and GPIO-2 are GPIO33 , GPIO14
Yes but ı try fınd the A,B,C slot GPIO number and B,A D1,D2 gpıo number ın green termınal
Can you mark on the image, which port you want to know GPIO number?
(12-11-2024, 11:02 AM)admin Wrote: Can you mark on the image, which port you want to know GPIO number?
ALL port pls Sad
(03-16-2023, 05:31 AM)admin Wrote: Relay1:15
Relay2:2
#define ETH_ADDR        0
RS485:
RXD:35
TXD:32
GSM:
RXD:34
TXD:13
DI1:36
DI2:39
IIC BUS:
SDA:4
SCL:16
it already showed here.
Relay2:2
#define ETH_ADDR        0
RS485:
RXD:35
TXD:32
GSM:
RXD:34
TXD:13
DI1:36
DI2:39
IIC BUS:
SDA:4
SCL:16
What's the PHY gpio?I'm using 4.3.1 idf.
#define ETH_ADDR 0
Hello, please help me determine the RXD and TXD pins for the SIM800L on the A4S board. The pins mentioned (13 and 15) in this forum thread do not work. I also want to point out that on the A2 board, the pins for GSM were listed as 13 and 34 as mentioned here, but in reality, they turned out to be 13 and 5. I am using my own script on ESP-IDF.
this pins for A2 works well
#define UART_TX_PIN 5
#define UART_RX_PIN 13
this pins for A4s doesn't work
#define UART_TX_PIN 34
