unable to login to Kincony server
KC868-Server
1. Default username: ? and password: "same as username" not working.
Is there a way I can reset the password?
2. I ran a Scan Device tool, I noticed that it doesn't respond with port "4196" on the Server results as per the attachment below. Please assist:
you can use user name: admin password: jingkong to login, then change to your own setting.
(03-24-2023, 12:04 AM)admin Wrote: you can use user name: admin    password: jingkong    to login, then change to your own setting.
Working. Thank You.
you are welcome.
