06-18-2023, 10:41 AM
About:
https://www.kincony.com/16-channel-ether...-h16b.html
After consulting the website and documentation. Could anyone clarify, please the following:
For the Input Ports:
What is the voltage input range / type of input / type of current for the inputs of the module?
There is NO INFORMATION regarding these ports!
f.e. DC 0-5V dry contact
or AC 230V
or whatever.
For the Output Ports:
Are they isolated? Can be used for different phases? i.e relay1: Phase1-N, relay2: Phase2-N.. relay{n} phase{1,2,3}-N
Can be the unit operated at 10A/per port continousuly? (what is the duty service?)
For the "working voltage":
What is the tolerance for the power supply? In volts or %. What is the maximun current drained, I.e. mx operational power of this unit?
In general:
What is the derrating with altitude / ambient temperature (stated as -20 to +70 C)?
Are there diagrams regarding mounting spacing required (safe areas, clear areas) and hole spacing?
I think the "product parameters" for most of the products should be updated to reflect more "basic" information.
Thank you.
or AC 230V
or whatever.
In general:
Thank you.
