Learn the remoter of E8T
Good Day! I would like to use one RF  button for turning ON and turning  OFF all the relays of KC868-E8T. Same with the functionality in tuya where there is ALL ON and ALL OFF button.
Since the RF remote contain 16 Buttons. Hoping for your response
do you want: remote button key1->relay1, key2->relay2, key3->relay3, key4->relay4, key5->relay5, key6->relay6, key7->relay7, key8->relay8,key9->8 relay ALL ON, key10->8 relay ALL OFF?
(07-25-2023, 08:50 AM)admin Wrote: do you want: remote button key1->relay1, key2->relay2, key3->relay3, key4->relay4, key5->relay5, key6->relay6, key7->relay7, key8->relay8,key9->8 relay ALL ON, key10->8 relay ALL OFF?
if possible , ALL ON and ALL OFF for key 9-
suggest use two different button. unless if your hold on the remoter's button, all relay will ON/OFF/ON/OFF loop.
(07-26-2023, 10:27 AM)admin Wrote: suggest use two different button. unless if your hold on the remoter's button, all relay will ON/OFF/ON/OFF loop.
its ok for me to have one button each for all ON  and all OFF key 9 >all ON and key 10 >all OFF . can you guide me how to do it
it need modify arduino code, already sent you source code. you need to check by yourself.
(08-04-2023, 12:18 AM)admin Wrote: it need modify arduino code, already sent you source code. you need to check by yourself.
can you share as well all the library i need to inlude ?
which library? list at here.
(08-09-2023, 10:52 PM)admin Wrote: which library? list at here.
you have send me the source code for the 8 channel and found out that there are errors even though i include all the library that i will be needing. I just need to modify the RF side but having errors while verifying causing me time
to modify the RF Side ., Kindly assist me on this matter
