Smartfarm solutions by KC868 Smart Controller
(Smart Power Distribution Box with inverter) For Fans:
1. Control fans for:
  --A. Turn ON/OFF power
  --B. Change fans’ speed (hight,mid,low)
2. Control fans by mobile phone,PC.
3. Supply two verison of software:
  --A. need internet for remote control
  --B. without internet for local control
4. Temperature and humidity automatic control fans:
  --A. E.g. Temperautre >35℃ Then fan speed=high
  --B. E.g. Temperautre <25℃ Then fan speed=low
  --C. E.g. humidity >85% Then fan speed=high
  --D. E.g. humidity <70% Then fan speed=mid
  All trigger conditions and fan control mode can be set by PC software. Automatic running locally without internet.
5. Inverter+Thermal Relay+ACB (air circuit breaker) connect to Fan Motor, So that any fan failure, inverter will shutdown for protection.
(Smart Power Distribution Box without inverter) For light and pump:
1.Control light or pump for Turn ON/OFF power
2.Control light or pump by mobile phone,PC.
3.Supply two verison of software:
  --A.need internet for remote control
  --B.without internet for local control
4.Temperature and humidity automatic control:
  --C.E.g. Temperautre >35℃ Then Device=ON
  --D.E.g. Temperautre <25℃ Then Device=OFF
  --E.E.g. humidity >85% Then Device=OFF
  --F.E.g. humidity <70℃ Then Device=OFF
All trigger conditions and switch control ON/OFF can be set by PC software. Automatic running locally without internet.
