Threads: 1,596
sure, there are many free GPIOs on KC868-Uair's PCB. you can use two GPIOs for i2c bus SDA and SCL.
Threads: 2
thanks admin
How can I order KC868-UAIR product and bme-680 product as bundlec on Aliexpress ?
Threads: 1,596
we not have bme-680, you can buy bme-680 from other seller.
we sell KC868-UAIR.
Threads: 2
thanks admin
I will buy the product as bundle2
I will buy bme680 from another seller
I request you to write me the bme680_bsec connection diagram and integration details.
If it is possible to connect sht30 and bme680_bsec at the same time, I need the connection diagram, yaml and other information.
thank you for your support
Threads: 1,596
i2c bus use 3.3v,gnd,SDA,SCL , total 4 wires connect to sensor.
Threads: 2
hello admin,
I purchased your KC868-UaiR from aliexpress.
I got the product after a long wait
I have some questions
1) Is esphome or kincony firmware installed on the product? Because there is no movement in the LEDs.
2) If you have a yaml file that runs the esphome led + ir + rf functions, could you share it with me?
3) Could you send me an example of a yaml file containing the mqtt structure that records the IR control codes and sends the codes to devices that work with IR?
Threads: 2
hi admin,
"if you really don't understand how to do, ok, when i have free time, make a video tour for you, how to learn IR and RF and send by MQTT"
I need this video very much. I would be grateful to you
thanks
Threads: 1,596
ok, next week have i have free time, will make it.
