Threads: 1
10-27-2023, 11:03 PM
Good evening, I have not purchased the product yet, but I am very interested. I have some doubts about the KC868-A16 model, namely:
How many relay expansions does it support connected to the bus?
How many relay expansions does it support connected via Ethernet cable?
I ask you this because I have to install them in different places in my house.
Thanks in advance.
Threads: 1,576
if you want install to many different places, you can chose some small channel ethernet relay module. such as KC868-A2, KC868-A4S, KC868-A8, so that place in any room, just need connect to your router by network cable is ok. all board use by one same software.
Threads: 1
Hi, so could I install only KC868-A2, KC868-A4S, KC868-A6, KC868-A8 in the various places by connecting them to the internet and integrating them on the home assistant without taking the KC868-A16?
Thank you
Threads: 1,576
yes, you are right, that is flexible, every board only need connect ethernet cable. just all network cable in one local network.
Threads: 1
Hi, thanks so much for the information... I'll make the purchase!
Threads: 1
Hi, but can I use the 16 digital inputs with a home assistant without controlling the relays on board the KC868-A16 board?
Meaning what:
When the digital IN1 is closed, when programming a scenario on the home assistant I would like it to energize a relay on another board...
I can?
Thank you
Threads: 1,576
sure, if without home assistant, use KCS v2 firmware, also can do that.
