12-25-2023, 12:43 AM
A24 wiring circuit diagram
05-28-2024, 12:08 AM
Hi, I am interested in making a panel similar to this one. https://www.kincony.com/32ch-smart-distr...stant.html . I need 2 breakers to be 32 Ampers. I only found 24v models.
How could I have a mix of 12v and 24v Ac connectors at the same time? I also see this excellent video https://www.youtube.com/watch?v=FE5fSduc0uI&t=597s . I only see 1 12v power supply. If someone could guide me. Great
05-28-2024, 01:47 AM
let controller's relay "COM" with a dc24v power supply, "NO" output to DC contactor's coin. so that can control ON/OFF 24v voltage.
My mistake sorry. So you connect the 220V L. to the A24 (in the coms) and then directly to the conector? Thanks!
any recommendation 32Amp https://es.aliexpress.com/item/100500379...pt=glo2esp 25 amp https://es.aliexpress.com/item/330118466...pt=glo2esp
05-28-2024, 02:34 AM
hi.. So just the A24 as a bypass and connect directly the L to the COM and to the AC connector? Any recommendation like this ?
One for 32 and other for 25. https://es.aliexpress.com/item/330118466...pt=glo2esp https://es.aliexpress.com/item/100500379...pt=glo2esp THanks for advise.. Just want to be sure what to purchase
05-28-2024, 02:37 AM
yes, if use AC contactor, just use L to COM, so relay output to control AC contactor.
Its possible to use the rs485 in this board to detect consume with your rs485 meter (80a) adding this code to the yaml?
uart: id: mod_bus tx_pin: 33 rx_pin: 32 baud_rate: 9600 stop_bits: 1 parity: EVEN modbus: id: modbus1 uart_id: mod_bus modbus_controller: - id: a24 address: 0x01 modbus_id: modbus1 setup_priority: -10 update_interval: 5s sensor: - platform: modbus_controller modbus_controller_id: a24 name: "Voltage" id: modbus_voltage register_type: holding address: 0x64 unit_of_measurement: "V" value_type: FP32 accuracy_decimals: 2 - platform: modbus_controller modbus_controller_id: a24 name: "Current" id: modbus_current register_type: holding address: 0x6A unit_of_measurement: "A" value_type: FP32 accuracy_decimals: 2 - platform: modbus_controller modbus_controller_id: a24 name: "Active Power" id: modbus_Active_Power register_type: holding address: 0x76 unit_of_measurement: "kW" value_type: FP32 accuracy_decimals: 2 - platform: modbus_controller modbus_controller_id: a24 name: "Power Factor" id: modbus_Power_Factor register_type: holding address: 0x8E unit_of_measurement: "" value_type: FP32 accuracy_decimals: 2 - platform: modbus_controller modbus_controller_id: a24 name: "Grid Frequency" id: modbus_Grid_Frequency register_type: holding address: 0x90 unit_of_measurement: "hz" value_type: FP32 accuracy_decimals: 2 - platform: modbus_controller modbus_controller_id: a24 name: "Total Energy" id: modbus_Total_Energy register_type: holding address: 0x0 unit_of_measurement: "kWh" value_type: FP32 accuracy_decimals: 2
07-14-2024, 12:38 AM
don't post repeat question. post one topic is ok.
« Next Oldest | Next Newest »
Users browsing this thread: |
1 Guest(s) |
