M30 ESP32 I/O pin define
ETH_ADDR        0
ETH_POWER_PIN  -1
ETH_MDC_PIN    23
ETH_MDIO_PIN  18
ETH_TYPE      ETH_PHY_LAN8720
ETH_CLK_MODE  ETH_CLOCK_GPIO17_OUT
IIC BUS:
SDA:5
SCL:16
SPI BUS:
SCK:14
MOSI:15
MISO:2
WS2812 RGBW LED:12
ARM CPU TXD:32
ARM CPU RXD:33
4G:
RXD:13
TXD:4
Hi Admin,
Any chance you might have a screenshot of this devices ESPHome webserver interface, showing the sensors it provides?
Does it provide just Active Power / Energy kWh (for what time period..i.e. hour / day ?) or also provide Current / Voltage / Power Factor?
How often are readings sampled and updated?
Is / how is, the ZMPT101B sensor calibrated ?  See: https://github.com/esphome/feature-requests/issues/2684
if you are using M30, you can download KCS firmware for M30. it support auto discovery with mqtt, so zero config for home assistant. also support many data monitor by voltage, current, power, energy , frequency.
https://www.kincony.com/forum/showthread.php?tid=6475
[Image: attachment.php?aid=5858]
Thanks but ESPHome is better as also allows using custom components, such as ones that automatically track energy usage per day / yesterday / week / month / year and adding tariffs.
Back to the original (unanswered) questions though...
  • How often are readings sampled and updated?
here is esphome yaml file for M30 , just directly to use: https://www.kincony.com/forum/showthread.php?tid=4088
(02-23-2025, 08:41 AM)admin Wrote: here is esphome yaml file for M30 , just directly to use: https://www.kincony.com/forum/showthread.php?tid=4088
Please, I keep asking for answer to these questions and the reply ignores them....
because M30 manager all data by BL0910 chip. not need calibrate for ZMPT101B
My friend, you will not get any answer..
Unfortunately the after sales "service" is just NON-existent.
I found out more by myself than from the "answers" I got asking here. And imagine I've spent more than 1000$ on their products. I was looking for M30 as well, thus I got to this - non answered- thread.
Dear Kinkony, you have to understand that product SUPPORT is as important (if not MORE important) than product quality.
If you have trouble understanding BASIC questions, do not reply randomly. Hire someone who speaks proper English and give them the answers to provide to customers.
