11-19-2020, 11:52 PM
Field Hold time: 2S in execution wait 20S, mean 10x than you set.
BUG in IFTTT
11-20-2020, 12:57 AM
what version you have download, because we have upload a new version in 2020-11-09. You can download the new version:
https://www.kincony.com/download/Kincony_SCB1109.zip
11-20-2020, 07:27 AM
(11-20-2020, 12:57 AM)admin Wrote: what version you have download, because we have upload a new version in 2020-11-09. You can download the new version: Use version what was on your web/documents. Please make this pages update, and also my idea to start log versions with version number and what updated in new versions. It is necessary for any software.
If possible make more readable IFTTT statements as maybe on picture.
Does possible make Editor this statements without going to satements Wizard, maybe direct edit in text. (11-20-2020, 12:57 AM)admin Wrote: what version you have download, because we have upload a new version in 2020-11-09. You can download the new version: yes in new version show as set, but I look hold time is still 10 sec. after reached set triger temperature, I set 30C or more, when reached this 30C, wait 10 sec. to relay closed. Also maybe you use negative Logic when declare Relay go to OPEN in real relay Closed and oposite. If still use same logic, Open is 'Off' or '0'; Closed is 'On' or '1'. Please check, maybe I am in wrong (11-20-2020, 07:27 AM)Nebojsa Wrote:(11-20-2020, 12:57 AM)admin Wrote: what version you have download, because we have upload a new version in 2020-11-09. You can download the new version: version in software title.
11-22-2020, 02:06 AM
(11-20-2020, 09:55 AM)Nebojsa Wrote: If possible make more readable IFTTT statements as maybe on picture. There is an option for "Temperature difference value" in menu "Parameter". it means when temperature exceed what value is for effective trigger. you can set to "1". (11-22-2020, 02:06 AM)admin Wrote:(11-20-2020, 09:55 AM)Nebojsa Wrote: If possible make more readable IFTTT statements as maybe on picture. I talk about problem, you talk where I made mistake, Not conside if no mistake, If COL controller firmware bad work. my version is new, and my parameters as is on picture. I make video to Ma. spend 3 hours to edited and send you to see clear where is problem.
11-23-2020, 01:35 AM
we have checked, make > temperature and < temperature trigger relay output , all is ok.
we will take two video for demo show you, will upload to google driver later and give you link.
this is test video temperature>28℃ relay ON: https://drive.google.com/file/d/1O6wlmbi...sp=sharing
this is test video temperature<25℃ relay OFF: https://drive.google.com/file/d/1aHVjwUi...sp=sharing
11-23-2020, 07:23 AM
you can try to write IFTTT command, then read from KC868-COL, check the data whether correct.
« Next Oldest | Next Newest »
Users browsing this thread: |
