PT1000 to KC868-A8 by ADC
Hi,
Is it possible to connect a 2-wire PT1000 sensor to the KC868-A8 (by using ADC)?
I connected my PT1000 to A1 and GND, but i get these readings in esphome:
[12:20:21][D][sensor:094]: 'Temperature_4': Sending state 0.14200 V with 2 decimals of accuracy
[12:20:22][D][sensor:094]: 'Temperature_3': Sending state 0.14200 V with 2 decimals of accuracy
with this setup:
  - platform: dallas
    address: 0x453c3ee381b36028
  - platform: dallas
    address: 0x783ce104577f4c28
  - platform: adc
    pin: 34
    update_interval: 5s
    attenuation: 11db
  - platform: adc
    pin: 35
    update_interval: 5s
    attenuation: 11db
I found this picture bellow, do I have to add 12v to the sensor? How do I do that if my PT1000 sensor has 2 wires? [Image: attachment.php?aid=2917]
no, can't connect with analog input directly. because our board analog input use by dc 0-5v signal.
Thank you for your quick reply.
Is there a way to connect my pt1000 to my KC868-A8?
How about with this https://esphome.io/components/sensor/max31865.html?
How would I connect that to the KC868-A8?
if you can use K type thermocouple, you can use KinCony A24, that use by MAX31855, support 3CH K type thermocouple.
But I already have the Kincony KC868-A8. Is there not a way to connect a max31865 to this board? Maybe by using the 433mhz pins? Or via the IIC extender?
no, MAX31865 use by SPI bus, A8 board not have SPI bus. if you can find out I2C bus solution chip,then you can use .
Is there another way to connect the pt1000 to the KC868-A8? (without a max31865)?
you can use this: https://www.hicomponent.com/pt100-to-0-4...itter.html
PT1000 convert to 0-5v signal.
(02-26-2024, 10:27 PM)admin Wrote: you can use this: https://www.hicomponent.com/pt100-to-0-4...itter.html
Perfect! I will give this a try
