KinCony Cloud Server will stop service in 2025 upgrade to TUYA app
KinCony Cloud server have worked almost 10 years for user freely use.
at the beginning of 2025, will stop service. In order to have a better user experience, we suggest use Tuya app with Tuya cloud server. There are two solution for update your OLD controller to use tuya app.
1. replace with new relay controller for more powerful functions.
8 channel old relay controller: replace with KC868-E8T or KC868-A8S or KC868-A8Sv2
16 channel old relay controller: replace with F16 controller
32 channel old relay controller: replace with A32 Pro controller
2. add tuya adapter let your old controller work with tuya app and support voice control by alexa and google home speaker.
8 channel old relay controller (KC868-H8/H8W):
add tuya adapter v2:https://www.kincony.com/esp32-tuya-iot-adapter-v2.html
video tour: https://youtu.be/zSOtzTXvUiI
16 channel old relay controller (KC868-H16/H16W):
video tour: https://youtu.be/6jevfQFY9A0
32 channel old relay controller (KC868-H32, H32L, H32LW, H32B, H32BS):
add tuya adapter v1:https://www.kincony.com/esp32-tuya-iot-adapter.html
video tour: https://youtu.be/z67pRMLb4Rc
Can i use one Tuya adapter for multiple controllers, or do i need Tuya adapter for every single controller?
What is the difference between tuya adapter and KINCONY ESP32 TUYA IOT ADAPTER V2 RELEASED?
different appearance, V2 not support by WiFi, only support RS485.
suggest you add V1 adapter for controller.
V2 main function see the webpage: https://www.kincony.com/esp32-tuya-iot-adapter-v2.html
But in this video ➡️https://youtu.be/rPmSf_mqeYc?si=3UB9TwEVfj_ZVvAC
Explained that there is an option to use the tuya adapter V2 with wifi.
I got mixed up!!
I would like you make this point more clear !
default have not weld the IPEX antena socket, if you want to use wifi, you can open the blue plastic shell, weld the IPEX socket, conenct with a extend wifi antena, then it can work by Wifi.
HI,
I have two h32Ls with long range modules and a first model COL at home.
How and what do I need to update?
add one tuya adapter, so that can use tuya app and voice control by alexa or google home speaker.
Is just one Tuya adapter enough for all my devices?
However, I have all the serial ports occupied and the controllers connected via LAN.
use one tuya adapter for your one H32L relay controller, COLB not need tuya adapter.
tuya adapter connect to your router by wifi, will send command by network, so you not need connect any cable with your H32L relay controller, only need set H32L ethernet work mode = TCP Server.
