04-19-2024, 01:11 AM
I am running two kc868-A6 with tasmota with no issues. I received my kc868-A8 and trying to flash it using the Kincony flash tool but it won't flash.
I am trying to load KC868A8_V2.0.6.bin with no luck and tried the latest version of Tasmota with the same results.
I get the following:
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
FLASH_CRYPT_CNT 0
ABS_DONE_0 False
is stub and send flash finish
In the tool panel I see a "AP number STA: number, BT: number and Ethernet: number
But the tool does not show it uploading.
I am still pretty green when working with Kincony boards, what am I missing? Is there something I need to do on the board?
I am using the CH driver and assume I am talking to the board given the panel is showing the AP, STA,BT and Ethernet?
Any help would be appreciated. I watched the videos and followed them exactly.
Also, could someone provide a URL for the scan tool, the link does not seem to work.
Uploading stub...
Running stub...
Stub running...
Changed.
FLASH_CRYPT_CNT 0
ABS_DONE_0 False
