Firmware Input
What version did the input parameters in V1.0.27 disappear from later versions?
which board model you are using?
kc868-a64
A64 suggest use V1 firmware. V2 is cost many memory. because V2 use by IFTTT.
Will version 2 ever work on A64? If not will there be any improvements to version 1.0.27?
what function you want to use by KCS firmware? whether you will use tuya app?
(05-13-2024, 04:05 AM)admin Wrote: what function you want to use by KCS firmware? whether you will use tuya app?
Would be nice to name inputs for documentation like in ifttt in version 2. Don't plan on using tuya.
if you don't use tuya, you can download KCS v2 for A64 board. because tuya will cost many memory, if use tuya by KCS v2, maybe will have error.
