Troubleshooting: Binary Sensor Entities Not Appearing
Why aren't binary_sensor entities for mini server appearing even though I followed the same tutorial in the video
https://www.youtube.com/watch?v=J5GRh7Gk...KinConyIoT
and used the provided codes as shown ?
I kindly request assistance in using these entities
  - platform: rpi_gpio
    switches:
      - port: 5
      - port: 22
      - port: 17
      - port: 4
      - port: 6
      - port: 13
      - port: 19
      - port: 26
    sensors:
      - port: 18
        invert_logic: true
      - port: 23
        invert_logic: true
      - port: 24
        invert_logic: true
      - port: 25
        invert_logic: true
      - port: 12
        invert_logic: true
      - port: 16
        invert_logic: true
      - port: 20
        invert_logic: true
      - port: 21
        invert_logic: true
do you have installed platform: rpi_gpio by HACS?
Yes ,I have installed platform: rpi_gpio by HACS
Why did the relay output appear?
these days i will have a test. then feedback to you.
i have tested, because the home assistant updated, so the library need to update, here is news: https://github.com/thecode/ha-rpi_gpio/issues/255
Hello, have you been able to find a solution to this problem or are you still searching for a solution? I am unable to control the device and I need assistance if possible. Thank you very much
i think you can use this one: https://github.com/jdeneef/ha_gpiod
when i have free time, i will test it.
sorry for the delay. today i have installed new component , it work well with RELAY OUTPUT and INPUT ports.
here is my yaml file:
  - platform: gpiod
    switches:
      - name: "CM4 relay1"
        port: 5
      - name: "CM4 relay2"
        port: 22
      - name: "CM4 relay3"
        port: 17
      - name: "CM4 relay4"
        port: 4
      - name: "CM4 relay5"
        port: 6
      - name: "CM4 relay6"
        port: 13
      - name: "CM4 relay7"
        port: 19
      - name: "CM4 relay8"
        port: 26
  - platform: gpiod
    sensors:
    - name: "CM4 IN1"
      port: 18
    - name: "CM4 IN2"
      port: 23
    - name: "CM4 IN3"
      port: 24
    - name: "CM4 IN4"
      port: 25
    - name: "CM4 IN5"
      port: 12
    - name: "CM4 IN6"
      port: 16
    - name: "CM4 IN7"
      port: 20
    - name: "CM4 IN8"
      port: 21
just use this: https://github.com/jdeneef/ha_gpiod    install by HACS
here is photo when i test with OUTPUT and INPUT.
