GND input
My question concerns the GND inputs on the Kincony KC868-A32 Pro module. Are the 5 GND inputs interconnected? Can I use only one GND input with the 40 dry contact inputs since I have grouped all my GND connections onto a single terminal block?  Should each set of 8 dry contact inputs be connected to their own GND?
Are the 5 GND inputs interconnected? Yes
you are right, only connect with one GND terminal is ok.
(06-01-2024, 01:47 AM)admin Wrote: Are the 5 GND inputs interconnected? Yes
thanks
