Maximum Cable Length?
Hi all!
What is the maximum cable length that can be used between the KCOM and each input terminals? Would 50 metres of AWG24 cable (0.215mm2 / 14/0.2mm stranded) be OK? How can we calculate the acceptable voltage drop? Thanks.
KC868-AI digital input ports support MAX 300 meter any cable to use. we have designed long distance circuit. 50 meter no any problem.
