I was referring to the E16P POE design and found that B1601S does not support POE. So how does it work?
E16P POE Support
07-19-2024, 12:58 PM
do you have used KC868-E16P board?
E16P+POE already used by many customer , why can't use it?
08-12-2024, 07:51 AM
I have some doubts, because I have had different POE devices burned out, so I want to confirm whether you mainly use 45+ 78- or 12+ 36-. Will there be any problems if the POE Switch uses 12+ 36-?
我有些疑慮,因為我曾經有不同的POE設備燒毀,所以想確認你們主要是用45+ 78- 還是12+ 36-,如果POE Switch 是使用12+ 36- 會有問題嗎?
08-12-2024, 11:08 PM
do you using E16P board?
which POE module you are using? whether from KinCony?
08-13-2024, 02:10 AM
Nope, but I will buy A8SV2 and try POE to see if it meets our needs. E16P is too expensive.
The damaged equipment belongs to other manufacturers, not yours. We want to reduce errors, so we are asking.
08-13-2024, 05:50 AM
DP5312 is12V 2A
DP5324 is 24V 1A PM0503T is 5V 2.4A --------------------------------------------------------------------- DP5312 (12V 2A) POE mdoule use for E16P(12v Omron relay) DP5324 (24V 1A) POE mdoule usefor E16P(24v Omron relay) PM0503T (5V 2.4A) POE mdoule use for A8Sv2, M16v2 here is order link of POE module: https://shop.kincony.com/products/rj45-p...s=e&_v=1.0 |
« Next Oldest | Next Newest »
Users browsing this thread: |
