A16 Configure RC 16 CH buttons Home Assist
Hi.
I want to activate the 16-channel remote control and it is necessary to configure the buttons on the remote control as well as the settings for RF.
The controller is linked to HOME Assistant.
I defined the RF channels in the YAML file, but I can't find where I can map the buttons of the remote.
I also don't find that the HOME ASSISTANT recognizes the remote.
Thanks for the help.
two way to use RF remote:
1: config by ESPHome, how to config , you can see here: https://esphome.io/components/remote_receiver.html
also here is KC868-A8S RF remote yaml demo, you can change the RF receiver pin define for KC868-A16S:
https://www.kincony.com/forum/showthread.php?tid=1946
2: download KinCony KCS firmware, directly to learn RF signal, make IFTTT work with relay output. Integrate to home assistant by MQTT.
