KC-868 AIO
Hi!
I received my new AIO!!!
Nice and fun. I managed to create the yaml file from your example Smile
All work fine but .... I have a curiosity. is a way to let say "map" digital input 1 to output 1?
My scenario:
I want to user "click" buttons to turn on the light, connected to a digital input.
When I press the button 1/ digital input 1, I want taht output 1 to turn on.
If the output 1 is on, when I press the button, I want that output 1 to turn off.
I'm using Home Assistant.
Thank You!
Never mind!!
I figured out !
pcf8574: pcf8574_hub_in_1
mode: INPUT
on_press:
then:
- switch.toggle: aio_light1
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
Thank You!
yes, it's easy, good.
