Compatibility with RF433 Superheterodyne Module?
Hi everyone,
I’m looking for some advice on the KC868-A16 board. I want to know if it is compatible with a 433 MHz Superheterodyne RF module. Previously, I had issues with signal range using common 433 MHz RF modules, so I bought the Superheterodyne module to test it. However, when I tried using it with a 433 MHz alarm sensor, it didn’t detect the signal when I attempted to learn it using the KCS firmware.
I’m fairly new to this and just started experimenting with this board today. I also haven’t soldered the antenna to the RF module yet, but I was testing the sensor right next to the module.
Has anyone had experience with this setup or could offer any insights?
Thanks in advance!
when you download firmware, need remove the RF receiver module.
if can't learn by KCS firmware, maybe your remote's data code not supportted.
(08-09-2024, 12:28 AM)admin Wrote: when you download firmware, need remove the RF receiver module.
Thanks for the reply. I had installed the firmware first and then connected the RF module. So it wouldn't be a compatibility issue, maybe it's just that the RF transmitter I used for the test is not compatible, as you said. I'll try another one. Thanks!
ok
2 Guest(s)
