Threads: 2
How can i communicate with plc (Plc as a master)? How plc can change my parameter ? For example plc wants to change or read my maxhumidity parameter, how can plc know maxhumidity modbus adress(for example 4x2002) ? Can you explain all phase communication, i dont know maybe assign modbus address, if plc change my parameter how can i catch and change parameter, ..? I hope it was understandable.
Threads: 1,576
i don't understand your means. if you can draw a photo will be better.
Threads: 1,576
1. Yes, it's ok
2. you need to write program code for support HMI, such as use Arduino IDE.
3. write your own code to set slave address.
4. according to your own code.
so all need you write your own software code.
Threads: 1,576
yes, if you will use arduino IDE, just use "serial" component.
