Threads: 1
Hi! I want to know if it is possible to connect more than 3 DS18B20 sensors to the KC868-A16 board, using the KCS Firmware, not ESPHOME! Via ESPHOME, I can find the addresses, but is it possible to do it with KCS Firmware? Thanks!
Threads: 1,589
you can check how many sensor option items in "SENSOR" webpage using KCS firmware.
Threads: 1,589
sorry, KCS firmware MAX 3. if you want use more, you can config by ESPHome.
