error on compling - ethenet
hello,
in my home I have several problems with WiFi so I'd like to connect via ethernet port.
So I adapted the code at this link to my needs.
This is this part of code i'm using
  platform: ESP32
  board: esp32dev
# ethernet configuration entry
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
# Optional manual IP
# manual_ip:
# static_ip: 192.168.0.199
# gateway: 192.168.1.1
# subnet: 255.255.255.0
web_server:
  port: 80
captive_portal:
# Basic Config
  sda: 4
  scl: 5
pcf8574:
    address: 0x24
    address: 0x22
when I try to compile, i receive the follow error:
C:\Users\Daddy>esphome compile c:/esphome/luci2_eth1.yaml
INFO ESPHome 2024.10.0
INFO Reading configuration c:/esphome/luci2_eth1.yaml...
INFO Unable to import component type: No module named 'esphome.components.type'
Failed config
type: [source c:/esphome/luci2_eth1.yaml:8]
  Component not found: type.
  LAN8720
Someone knows how I can solve this prolem?
many thanks
if you are using KC868-A2, you can use this link of ymal file directly to test:
https://www.kincony.com/forum/showthread.php?tid=2692
