10-22-2024, 01:25 AM
This code controls 1 WS2812 RGB LEDs connected to GPIO 16 on an ESP32-S3.
Each LED will be set to blue with adjustable brightness.
The Adafruit NeoPixel library is used to communicate with the WS2812 LEDs.
Hardware setup:
- WS2812 RGB LEDs are connected to GPIO 15 (data pin).
- Total number of LEDs: 3.
#include <Adafruit_NeoPixel.h>
// Create an instance of the Adafruit_NeoPixel class
// Parameters: number of LEDs (3), data pin (GPIO 15), LED type (NEO_GRB with 800 KHz communication)
Adafruit_NeoPixel rgb_display = Adafruit_NeoPixel(1, 16, NEO_GRB + NEO_KHZ800);
// Initialize the NeoPixel library and prepare the LEDs for use
rgb_display.begin();
rgb_display.setPixelColor(uint16_t n, uint32_t c);
This function sets the color of a specific LED.
Parameters:
- n: The LED number (starting from 0).
- c: The color to set the LED to, in hexadecimal (0x0000ff = blue in RGB format).
// Set the first LED (LED 0) to blue
rgb_display.setPixelColor(0, (0x0000ff)); // Blue color for the first LED (index 0)
rgb_display.setBrightness(100); // Set brightness to 100 out of 255
rgb_display.show(); // Update the LED to reflect the change
LED_WS2812B-1pc.zip (Size: 834 bytes / Downloads: 843)
LED_WS2812B-1pc.ino.merged.zip (Size: 179.91 KB / Downloads: 858)
