Hi
I have the KC868-A16S board and I have it setup up in ESPHome and linked to HA.
I´m having trouble connecting a one-wire ds18b20 temperature probe to the board and get a readout.
This is my yaml:
This is my yaml:
friendly_name: Kincony
platform: ESP32
board: esp32dev
#esp32:
# board: esp32dev
# framework:
# type: arduino
level: DEBUG
encryption:
key:
sda: 4
scl: 5
# Example configuration entry
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
# Optional manual IP
# manual_ip:
# static_ip: 192.168.1.199
# gateway: 192.168.1.1
# subnet: 255.255.255.0
one_wire:
pin: GPIO14
# Individual sensors
- platform: dallas_temp
#address:
update_interval: 5s
external_components:
- source:
type: git
url: https://github.com/ssieb/esphome
ref: onewire
components: [ gpio ]
refresh: 1min
pcf8574:
address: 0x24
- id: 'pcf8574_hub_out_2' # for output channel 9-16
address: 0x25
address: 0x22
address: 0x23
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
number: 1
mode: OUTPUT
number: 2
mode: OUTPUT
number: 3
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
pcf8574: pcf8574_hub_out_2
mode: OUTPUT
number: 1
mode: OUTPUT
number: 2
mode: OUTPUT
number: 3
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
pcf8574: pcf8574_hub_in_1
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
number: 6
mode: INPUT
number: 7
mode: INPUT
pcf8574: pcf8574_hub_in_2
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
number: 6
mode: INPUT
number: 7
mode: INPUT
