New KC868-A32 Arduino ESP32 32 Channel GPIO Module (with MOSFETs - without RELAYs)
What about a New KC868-A32 Arduino ESP32 32 Channel GPIO Module (with MOSFETs - without RELAYs like the existing model) ?
This will be more suitable for a family home which has around 32 switches and 32 lights.
Note: The number of digital inputs and digital outputs of the existing KC868-A16 model is insufficient for this type of house.
Thanks !
you can check with A32 Pro, it have 40 digital input, 32 relay output. or do you need MOSFET output? if YES, you can check with KC868-H32BS controller, it have 32 channel digital input ports and 32 channel mosfet output.
(11-06-2024, 10:10 AM)admin Wrote: you can check with A32 Pro,  it have 40 digital input, 32 relay output. or do you need MOSFET output?  if YES, you can check with KC868-H32BS controller, it have 32 channel digital input ports and 32 channel mosfet output.
Thanks for you reply!
A32 Pro : I don't need relays (I need MOSFET outputs).
KC868-H32BS : Has 32 channels digital inputs ports and 32 channels MOSFET outputs
                         But doesn't have ESP32 for ESPhome or Arduino code.
So I suggest you make something close to "KC868-H32BS module" but with ESP32.
Thanks!
OK, the shape similar as B16M style?
Would it be possible to program the IFTTT function in KCS please? so that the trigger of the function is also DO(x)
Example: Used for automatic shutdown after switching on DO(x) via MQTT
this is AUTO OFF function, you can set in "OUTPUT" webpage to config it. Then relay will auto off after turnned ON.
Yes ! With 32 Digital inputs & 32 digital outputs like A16 ou like B16M without TUYA.
(11-07-2024, 11:45 AM)admin Wrote: OK, the shape similar as B16M style?
OK, in furture we will design B32M.
