Energy consumption not measured
Hi,
yesterday I received my M30 board and the installation was straight forward.
Now I have a problem that I can't explain. All 30 current clamp sensors do not measure the energy constumtion (kwh). Voltage, current and power are shown without any issue, but the energy sensors are always 0.00 kWh.
I´m using your yaml template for ESP Home and my goal is to integrate the sensors into the energy dashboard of Home Assistant.
I hope you can help me to solve this issue.
BR
Sebastian
take a photo , what's M30 KCS firmware version you are using.
upload your yaml at here.
Please find my yaml attached, but I don´t know how to read the current KCS firmware version.
Can you explain the steps in more detail?
It seems that my problem is caused by the inaccuracy of the decimal places of the energy sensors. Because now I have noticed that the value of the energy sensor has changed from 0.00 to 1.00 between 1 and 2 am.
As a result, the entire 1 kWh is suddenly displayed in the energy dashboard, which also leads to a negative deviation.
How can the accuracy of the energy sensors be increased to 1 or better 2 decimal places?
.txt   energymeter-house-1.txt (Size: 64.91 KB / Downloads: 410)
