Threads: 1
Hello everyone I'm building new house in Europe and I would like to Install all new home automation system .I would like to know can automation system can work "together" with normal switches and do I need to plug additional wires for example lights switches and what is that I need to install all together..regards
Threads: 1,599
suggest you use "momentary" switch panel work with smart system.
Threads: 0
Thank you for your suggestion! So if I use a momentary switch panel, does that mean I don’t need additional wiring, or do I still need to run extra wires for the automation system to work alongside normal switches? Also, do you recommend any specific brands or models for a reliable setup? Appreciate your help!
Threads: 1,599
you can use any brand momentary switch , just need connect wire to controller's digital input ports. such as by network cable.
