12-08-2024, 04:09 PM
Hello
I would like to build an AutoSteps staircase lighting controller that allows automatic control of the staircase lighting
in the staircase. Which gives the possibility of obtaining a decorative visual effect consisting of smooth
brightening and extinguishing of the stair lighting.
I would like the device to be configured using four buttons on the front (left/right/confirm/cancel - long press to return to the main screen) of the device and an OLED display, thanks to which I could change the staircase controller settings. It would be nice if the device allowed independent control of LED light sources up to 24 V DC. Do I need anything else besides the KC868-AP ESP32 DC12/24V LED Dimmer to control the brightness of the lights?
Control with a PWM signal:
• LED bulb, LED strip, LED module, LED strips, LED eyes
To be able to connect a signal from motion sensors at the beginning and end of the stairs, which would activate animations controlling the brightness of the connected light sources.
Can I also add an RTC time module?
Is it possible to make such a controller?
Best regards
Best regards
