Yesterday, 03:59 PM
Hi! First time user here!
I've just received my KC868-A6, I'd like to connect it to my home assistant.
I'm trying to follow the instructions from https://www.kincony.com/esp32-kcsv2-firmware.html using the bin KC868_A6_V1.0.10.zip
I say "trying" because the instructions are a bit unclear to me when they start using the ethernet cable and the A6 doesn't have one.
I've managed to connect to the board through its wifi and accessing http://192.168.4.1.
From here, I assume I need change the wifi mode to STA and set my home wifi ssid and password and after that the KC868-A6 will be discoverable through the scan device program, right?
My issue is that I can't move forward from this point, after changing it to STA it never connects to my wifi and I need to restart it through the flash program to make the board accessible again.
What am I missing? Did I understood something wrong? I've tried 2g and 5g with the same result.
Thanks
Thanks
