01-15-2025, 03:04 AM
* RS485 Communication Test with Echo
* This program tests RS485 communication using ESP32-S3.
* It sends a message over RS485, reads incoming messages, and echoes them back.
* The TXD pin is defined as GPIO 9 and RXD pin is defined as GPIO 8.
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 18
#define RS485_TXD 17
while (!Serial);
// Send a test message periodically
// rs485Serial.println("Hello from KinCony A32 Pro!");
// Wait for a short period
delay(100);
// Check if data is available to read from RS485
String receivedMessage = "";
char c = rs485Serial.read();
receivedMessage += c;
// Print the received message to the serial monitor
Serial.print("Received: ");
// Echo the received message back over RS485
rs485Serial.print("Echo: ");
rs485Serial.println(receivedMessage);
delay(2000);
RS485.zip (Size: 810 bytes / Downloads: 768)
RS485.ino.merged.zip (Size: 184.34 KB / Downloads: 740)
